1999 CBR600F4 Rebuild (Photo Heavy)
Hello everyone,
I am new to the forums but not new to riding. I just recently bought a 1999 CBR600F4 that had been laid down then subsequently sat for a number of years. while sitting, it looks like one of the carbs drained the gas tank into the engine and turned to varnish. The sad part is that this bike only has 7000 miles on it. When it went down, it destroyed a lot of parts. It ended up damaging the following parts: mirror, front brake lever, clip on, throttle, side plastic, front foot peg, rear brake lever, rear foot peg, slip on, rear fairing, tail light, and the undertail fairing. due to the varnish in the engine, I had no choice but to tear it down (not to mention that it was seized). everything I have cleaned I have done so with nothing more than a brass wire brush, plastic brush, purple power, and acetone. here is the progress i have made thus far.
The day i picked the bike up
broken clip on and related components
broken foot peg and brake lever
bent foot peg and bashed muffler
broken tail fairing and missing tail light
Prepping to remove engine
no more engine
Engine out
signs of varnish and fuel staining on left side of head
top end of cylinder head looks pretty clean. I numbered each valve lash caps to make sure i dont mess up the lash
cylinder head removed
things look pretty nasty in here
you can see where the level of fluids were by the line of brown
clutch basket is smoked, a few are even broken into pieces. entire clutch pack was stuck together when i removed it
got the crank out and it looks unsalvageable
its not rust, its just varnish
the power of purple! purple power and a brass wire brush cleaned up the lobes pretty good.
cylinder walls look pretty good
look even better after a cleaning! (again, purple power and a plastic brush this time)
piston was stuck in the bore due to the varnished fuel and stuck rings. thankfully it didnt mess up the walls on the way out.
conn rod before...
conn rod after glass beading
transmission before...
transmission after glass beading (i disassembled it and didn't do the bearings of course)
oil pan before...
oil pan after cleaning with purple power and a plastic brush
bottom half of engine case before...
bottom half of engine case after cleaning with purple power and a plastic brush
how it sits while i wait for parts
clean as a whistle
no more engine
Engine out
conn rod before...
oil pan before...
clean as a whistle
The following users liked this post:
IDoDirt (06-13-2022)
project update:
i finally got the bike put back together yesterday. im very upset with myself because in the process of bolting the 2 case halves together, i did not notice that one of the bearings on the transmission was not aligned with its dowel pin and i ended up blowing the dowel pin out of the top of the case. i plan to fix that with the tig welder. put it all back together and went for a test fire and all i got was cranking and cranking and cranking...turns out i (like most of the people on this forum) DONT HAVE SPARK! I immediately assumed pickup coil so i put an ohm meter on it and i get an open reading. took the side cover off to find the wire broken right off at the base of the pickup coil. i have a new one on order (aftermarket Caltric) and hoepfully this will solve my problem.
Yin-Yang
04-26-2017 11:03 PM
Mattson
03-01-2014 06:01 PM
