1999 cbr f4 turn signals
i'm trying to find flush mount led turn signals for the front that require no drilling or anything. something that just bolts and plugs in. also looking for some good ideas for rear turn signals, i want to spend $130+ for a integrated tail light, anyone have good ideas?
on
1 Post
you can try hotbodies, Protons, etc..
here are some cheaper ebay ones that look good:
http://cgi.ebay.com/ebaymotors/Smoke...Q5fAccessories
Do a search.. this has been asked probably 4,324.274 times
For the rear, take your pic.. any stalk mounted will work. I have a set of stalk mounted ones that I would sell you cheap..no use for them.
I've tried about everything for the front signals. My evolution led me to the Hotbodies LED's. They are worth every penny. They are as flushmount as you'll ever get & are quality at that price-point for sure. There's even a write-up on this forum for wiring these up as running lights as well, if you so desired. Otherwise, they are plug-n-play like you want. http://www.hotbodiesracing.com/en/pr...004-06_cbr_f4i
I've run the gamut for rear signals as well. Currently, I'm using Motrax clear LED's that I purchased from CycleGear. http://www.motrax.co.uk/index.php?mo...uct&id_prd=114 . They are sufficient but not quite as bright as I'd prefer. However, they work pretty well.
Recently, I picked up a pair of DRG 601 LED's. http://www.drcproducts.com/elect/d45-60-107/index.html . The quality is certainly there. The are bright as well. Many of the offroad guys use these & swear by them.
Good luck.
Good luck.
Lowridese
05-01-2010 01:12 AM
