What's the issue with fitting an RR rear shock?
As you might be aware, I'm rebuilding my F3 & thought about fitting an 08RR shock.
I've dry fitted it & can't really see any issues, why do people not fit them? Are there problems that I can't see?
There is plenty of room around the reservoir even with the expansion bottle fitted.
I am going to try it, it's an easy job to swap over to std, so will see how it goes
Just so you know. If there is a difference of say 3mm between the two shocks, it will not equal a 3mm rise in the rear end. This is because there is a leverage ratio (X:1) due to the linkages in the rear suspension.
My guess with installing an rr would be clearance. You also have to remember that the shock compresses and extends and it could hit something during one of those motions. A good way to see if it's going to hit anything is to remove the spring and manually move the rear suspension from full extension to bottoming out. You could also calculate the leverage ratio while you're at it.
jnicola
F2 Tech
Sep 2, 2010 07:01 PM
