What size chain and sprockets do I need?
RE: What size chain and sprockets do I need?
for the F3's I like to go down one sprocket in the front and use a 520 chain. This will allow the bike to rev quicker in each gear and the smaller chain with allow unsprung weight to transfer to the rear wheel rather than being used to move the heavier chain. All in all the bikes feels snappier, not sure if thats a legitmate word.
Basically, if you go any size that's smaller in the front or bigger in the rear you'll get better acceleration but less top end power. Stock gearings is a 15 front 43 rear. Normal size chain is a 530, but you could go with a 525 or 520, just remember the chain will wear out faster if you go with a smaller chain.
ORIGINAL: kwong2001
A DID 520 chain will last longer than the oem 530 will.Betcha any amount of money or parts.
Another benefit of the 520 is that it will reduce (in small measures) wear and tear on the motor,due to less drag/weight.Every little bit helps
Actually your 97 F3 came with a 525 chain. So dropping to a 520 isn't going to make that much difference. If you go with alloy sprockets as opposed to steel (OEM is steel, and lasts longer), that could save some of the weight and improve on the excelleration. Naturally smaller sprockets in front or bigger in back with help as well. The issue there is you're going to effect your actual speed compared to the indicated speed on your speedometer.
ORIGINAL: kjohnson
Nope.
And the only difference with a 520 vs a 530 is the less rotating mass from the chain and sprockets so you'd lose less power at the rear wheel with a 520 vs 530.
cbrfxsmithy_6_7
04-11-2012 08:34 AM
