hey guys, can anyone tell me what this part is? yea the pics blurry but its the best i could do. its beside the oil filter under the header and has a single large line running out of the bottom. i need to relocate it so i can mount my adapter for the turbo oil lines.
If I read that correctly, you've got a turboed bike. Care to share some specs?? What turbo you planning on using? Sticking with the carbs?
well im working on it anyways. some parts are discouraging lime things being in the way blah blah. im using a stock td05h 16g turbo that came stock on older dsm eclipses. i plan on sticking with the carbs but upgrading to a walbro gsl392 inline fuel pump and mallory fpr. for the oil lines i bought an oil sandwhich that fits on crxs. a crx has the same oil filter thread pattern as our bikes. the turbo has oil feedlines so the sandwhich makes things a lot easier and there is no tapping the oil pan for the feed and return lines altho i still have to have steel braided lines made. i wanted to put the turbo on the front of the engine like turbo hyabusas are setup but i dont have a spare f3 header sitting around to cut up and modify. i have an f4 header but the flanges are different. all i have is the yoshimura header off the bike and i would rather not cut it up. so my plus thus far is to mount the turbo towards the rear of the bike at the end of the header where the pipes go into one. im not going for stupid power increases. im looking for something that is reliable yet will make it more fun to ride. im going for 4 to 5 psi
