what brake fluid to use
Old 07-13-2007, 05:58 PM
buddah's Avatar
Default what brake fluid to use
dumb question but i've searched everywhere for teh answer to no avail----does the f3 use dot 3 or 4 brake fluid and any recomendations on brands to use?
Old 07-13-2007, 06:06 PM
Default RE: what brake fluid to use
when i had my old F3, it said it on the res cap on the bike. i used dot 4.
Old 07-16-2007, 07:08 AM
Use DOT4. This is why...
DOT3
DOT3 brake fluid is the "conventional" brake fluid used in most vehicles.
Advantages:
DOT3 fluid is inexpensive, and available at most gas stations, department stores, and any auto parts store.
Disadvantages:
DOT3 fluid eats paint!
DOT3 fluid absorbs water very readily. (This is often referred to as being hydroscopic.) As such, once a
container of DOT3 has been opened, it should not be stored for periods much longer than a week before use.
Since DOT3 fluid absorbs water, any moisture absorbed by the fluid can encourage corrosion in the brake lines
and cylinders.
DOT4
DOT4 brake fluid is the brake fluid suggested for use in some late model cars.
Advantages:
DOT4 fluid is available at most auto parts stores, and at some (but not all) gas stations or department stores.
DOT4 fluid does not absorb water as readily as DOT3 fluid.
DOT4 fluid has a higher boiling point than DOT3 fluid, making it more suitable for high performance applications
where the brake systems are expected to get hot.
Disadvantages:
DOT4 fluid eats paint! Small leaks around the master cylinder will eventually dissolve away the paint on your
bodywork in the general vicinity of the leak, and then give rust a chance to attack the body of your car!
DOT4 fluid is generally about 50% more expensive than DOT3 fluid.
Since DOT4 fluid still absorbs some water, any moisture absorbed by the fluid can encourage corrosion in the
brake lines and cylinders.
DOT5
DOT5 brake fluid is also known as "silicone" brake fluid.
Advantages:
DOT5 doesn't eat paint.
DOT5 does not absorb water and may be useful where water absorption is a problem.
DOT5 is compatible with all rubber formulations. (See more on this under disadvantages, below.)
Disadvantages:
DOT5 does NOT mix with DOT3, DOT4 or DOT5.1. Most reported problems with DOT5 are probably due to some
degree of mixing with other fluid types. The best way to convert to DOT5 is to totally rebuild the hydraulic
system.
Reports of DOT5 causing premature failure of rubber brake parts were more common with early DOT5
formulations. This is thought to be due to improper addition of swelling agents and has been fixed in recent
formulations.
Since DOT5 does not absorb water, any moisture in the hydraulic system will "puddle" in one place.
Old 07-17-2007, 08:59 PM
buddah's Avatar
wow thanks for the input on all the different fluids! Dot 4 it is
Old 07-18-2007, 06:32 AM
Now that is an expert answer. Wow
Old 07-18-2007, 06:38 AM
A wonderful invention, the search engine...
It came from here... http://www.tccoa.com/brake-fluid/
johnnyx
08-22-2012 01:15 PM
CJardine
07-24-2012 09:41 AM
ThisisMickey
08-24-2007 03:38 PM
tutman6
08-27-2006 01:23 PM
hondacbr1000
07-22-2006 06:41 PM
Quick Reply: what brake fluid to use
