Way to test choke with carbs removed?
Is there a way that I can make the choke sliders inside my carb open up using suction? I blew air in the middle tube and it opened up the choke valves but whenever I create a suction on any of the tubes/hoses, it doesn't open up. Is there a certain way to do it or does it have to be connected to the engine to work? I'm getting nervous that my choke will be stuck. My bike is a 98 cbr f3.
Either we're not talking about the same thing or possibly your choke plate is physically stuck closed. As I said, you should be able to physically slide it open freely and a spring closes it. On the bike, the cable may need adjustment to fully open / close the choke
Ok, the slider thing is the choke (the second thing you showed). It has those oval-ish
holes that goes across the air-intake. When it is in the closed position it partially
restricts the amount of air that can be pulled INTO the carbs (i.e. choke the air flow).
The first things you were showing pins that seat on the fuel-intakes. YES, these are controlled by the vacumme. These are your main jets (I believe, my carb experience is still rather juvenile. That's why we keep IDoDirt around, lol).
Here is a fiche of your carbs...HONDA OF TULSA 1998 Honda Street Bike CBR600F3 Parts List
There is no testing that I'm aware of to be done to carbs while dismounted.
The only thing you do to the carbs is a minor dis-assembly of the fuel jets, and cleaning. then re-assemble and ball-park the main jets to allow final sync with the bike running.
I hope this helps your understanding, Ern
