very weird question
weird answer: its gonna be hard due to the fact that most aliens are color blind
if you gonna take the time to cut off the old subframe and weld in a new one for clearance issues i would go with maybe a 600rr subframe..... i know someone on these forums is doing that as we speak... looks awesome.. imo
welcome! what part of colorado are you moving too? this place is awesome
right on man, i grew up on the front range just a few minutes away from red rocks... high school at bear creek... been in Durango for about 7 years now.
hit me up if your ever in the area
if the idea is to get rid of the stock sub frame then cutting welding is a must.... you might be able to fab mounts onto the f3 subframe to accommodate different plastics
not a very weird question..
colorado_steve is right about the 600rr suggestion.or you could go with an 08-11 cbr1000rr tail. here's a link
https://cbrforum.com/forum/cbr-600f3...roject-138706/
you wouldnt NEED to weld this subframe, youd just have to weld in mount points and then just bolt it on..check out the link!
