very frustrating brake problem
ive been build my f3 from the ground up- and now im trying to put on the front pair of brakes on my f3, and for some reason when i tighten up the two bolts that support the brakes connecting to the fork, theyll lock up the front wheel putting pressure on the rotor. i dont believe they should be like that, is there something im missing or forgetting when to put the brakes back on?
Hey Ice,
Something you might want to take a look at is to check and see if your brake caliper bracket on the left side (from the rider's perspective) is contacting your disc, not your pads, causing the wheel to lock. If you download the repair manual, look at the page labeled "12-13" under the front wheel/suspension/steering section and make sure you set your fork width using the specified method. If the left fork is tightened into place using the pinch bolts either too narrow or too wide, bolting the caliper into place can cause the bracket to rub.
Hey Ice,
ya the caliper bracket it touching the top of the rotor causing it to lock up, im still having trouble figureing this one out, cause a few months ago i had put new pads on and reassembled no problem then i run into this problem.
