transmission repair, how to split the engine case
Old 06-15-2012, 06:05 PM
Jordan Fonte's Avatar
Registered Users
Default transmission repair, how to split the engine case
hi guys, so my 4th gear is missing, and i need to replace the transmission, and i wanted to know what parts of the engine do i need to take of, ive ben lookink at the manual and it seems that i have to take of to many parts to get to the transmission, any guess?
also is this a take apart and build or do i have to be carful with chain timing?
thanks
Old 06-17-2012, 10:20 PM
marc0011's Avatar
I am currently doing this because mine slips out of second gear and I developed a leak between the cases. Remove the exhaust and then remove the engine from the bike. You're going to have to remove the oil cooler, both left and right covers, and the oil pan. Afterwards, you need to remove the clutch basket and all the mechanisms behind it. You will need to remove the magneto and you can do this by using the big threaded engine hanger collar to back off the magneto. Lastly, remove the speedo sensor on the top of the tranny. Now you're ready to remove the bolts from the top and bottom of the engine. You don't have to remove the head from the upper case. I am building a horizontal case splitter so that I can split the cases without damaging the case surfaces.
Old 06-18-2012, 02:25 PM
cobra1000rr's Avatar
If you are good with mechanical work and have a manual to help you along its possible, but yes you are going to strip the motor off the bike and split the bottom case. If you are going to do it you should inspect the clutch or just replace it too since your there. If you want a shop to do it, expect to pay alot more than just buying another motor.
Old 06-19-2012, 03:43 AM
Registered Users
thanks, i was really looking into doing it myself, i have the manual to help, i was just wondering if i needed to mess with cam timing, or anything that will kill the engine.?
so to someone that kinda knows his way around an engine, how much time will i expect to change the transmission with the engine on the table?
Old 06-20-2012, 01:53 PM
Well no you do not have to mess with the timing, now you will have to remove the timing bracket that takes out the slack on the chain. As far as time goes I would not worry about how fast you can do it, more of take your time and make sure you do it right. Take pics of cables electrical etc to help put it back together. GL!
Old 07-08-2018, 10:17 AM
Pmartone's Avatar
Does the cam chain need to be removed?, or just the bracket?
Old 07-28-2018, 01:39 AM
edwardzx7's Avatar
You know this was from 2012??! If your doing this same procedure, the head will be separated from the block. So yeah, anything connecting your head will have to come off.
Pmartone
04-05-2019 09:39 AM
bammerman
06-22-2010 10:09 AM
94rbc
10-09-2008 09:00 PM
CoreyAkaOpie
05-19-2007 10:24 AM
mikeyvis
11-30-2006 06:46 PM
Quick Reply: transmission repair, how to split the engine case
