too rich, pls help!
too rich, pls help!
I bought a bike a couple of weeks ago and it was bogging at high RPM's. I sprayed carb cleaner in the carbs, and all it wanted to do was backfire, I believe i fouled the plugs. So, i cleaned the carbs, and changed the plugs and now it starts.. But it's SUPER rich, like i can see gas coming out of the exhaust basically, and if you let it idle for about 10seconds then hit the gas it bogs, then backfires.
I took the carbs apart and checked the fuel valve and float and they seem ok. I checked my air filter, it's ok. The smaller air filters, checked them. I ran some compressed air through the smaller filters and some of them had chunks of filter blowing out of the other end of them. The vacuum lines seem really tight, the ones that go to the solenoid.
ANY IDEAS?
ANY IDEAS?
I did see this spring when i took the carbs apart, and cannot find out where it goes.. It could be something essential?
http://i198.photobucket.com/albums/a...0624091342.jpg
That looks like the return spring that attaches to the choke bar.
The choke cable attaches to a bar on the front of the carbs and when you pull the choke, the cable pulls the bar to the right side of the bike, when you take the choke off the bar returns under spring pressure.
If this is the spring i think it is, then your bike is on full choke 100% of the time which would explain the richness. Are the RPM's high when your idling?
