timming
Old Aug 8, 2005 | 10:07 AM
phantom09086's Avatar
Default timming
i have a 97 cbr600f3 how the hell do you time it, where do the marks go and how do i know if its right, this bike is getting me pissed, it looks right by the book but it just cranks and some times back fires, also the hose i cant find where it goes is the coolent res siphine hose on the bottom of the coolent resivor tank or( overflow tank) please help.
Old Aug 8, 2005 | 10:55 AM
chainstretcher's Avatar
Admin Emeritus & MVN
Default RE: timming
The hose on the bottom of the reservoir tank should connect to the radiator -- just under the cap there's usually a 'spout' where that hose hooks to.
If the timing marks are aligned per the shop manual then you're golden -- when's the last time it ran and what did it do before it stopped running?
Old Aug 8, 2005 | 01:35 PM
Default RE: timming
i changed the 2nd gear shift fork, it was running when i put it back togather. then it died and would only idel when i gave it gas it died, then i messed with the idel now it just cranks, maybe i need to reset the idel,so how do i do that. also what do i do if its flooded.
Old Aug 8, 2005 | 07:18 PM
onlyridecbrs's Avatar
Default RE: timming
I am by no means a mechanic but have worked on my 97 F3. Mine had about 18,000 miles when it would crank, run for about 5 minutes (or until hot) then shutoff and wouldnt start back. While running it had a funny smell and would backfire. You need a real long phillips screwdriver to reach and clean all the carburators bowls real good. It fixed my problem and havent had any more trouble. Just a thought to help diagnose your problem.
Old Aug 8, 2005 | 07:34 PM
Default RE: timming
ok i will try that, but when its running and i give it gass thats when it stalls. also dose anyone know how to adjust the idel
pilam
Jun 7, 2006 02:43 AM
phantom09086
Apr 6, 2006 09:27 PM
phantom09086
Mar 31, 2005 06:26 PM
