-   CBR 600F3 (https://cbrforum.com/forum/cbr-600f3-17/)
-   -   tilt sensor (https://cbrforum.com/forum/cbr-600f3-17/tilt-sensor-147339/)
JLAvila Jun 8, 2013 06:49 PM
tilt sensor
Hey guys,
So my bike was previously a racing bike and I think they pulled out the tilt sensor but im not sure. Where is it located? Im having an issue where when the bike is on the stand, it will say neutral on the cluster and start but when I bring it up to start to ride, the neutral light will go off and the bike dies. Any ideas?
IDoDirt Jun 8, 2013 07:11 PM
The F3's don't have a BAS or Bank Angle Sensor. That is used for Fuel Injected bikes to kill the high pressure fuel pump in case of an accident. Having the bike die when you pull the bike upright does seem unusual. Anyway you could post a video or provide a more detailed description of exactly what happens and when ?
JLAvila Jun 16, 2013 01:38 PM
Hey IDoDirt-
Here is a video of the issue.
What was wrong with it the first time was one of the wires was torn up on the connector so I soldered it back together. Now the issue is this, when Im on the bike and its in neutral, the light doesnt really come on unless i put a little down pressure on the shifter without going into first or when I tilt the bike. I changed out the fuse after it blew yesterday and the bike also dies when im in neutral and put the stand down. Another issue is sometimes when I let the bike sit for a while and go back to ride, I will put it in gear and it will die out, Its like it doesnt know its in neutral.
What could be the issue?
MadHattr059 Jun 16, 2013 08:11 PM
Check the clutch switch , on the bars.
Also check the side-stand switch.
Will it kill the bike if you are pulling the clutch when you lower the side-stand?
By eliminating a wanky connection at those points,
it help assures that it they aren't contributing to the issue.
The neutral light thing is really weird, so it might not help.
It really sounds more like a bad neutral sensor
or a wire/connection in that part of the circuit.
Hope this helps, Ern
f3cbrAnt Jun 16, 2013 08:12 PM
" I will put it in gear and it will die out, Its like it doesnt know its in neutral."
You never know that could save you time pin pointing the problem.
R/R faulting - all the way through to the dashboard assembly!
JLAvila Jun 17, 2013 02:17 AM
The thing is, that it only does every so often which is weird. Usually after I road the bike for a little while
jackojeff Jun 18, 2013 06:07 AM
volt meter in hand bike stripped downafter your carb clean ;) follow the wire from the side stand switch up to the connection and test the wires somewere in my threads is a picture of what wire should show what and when, have a look.
