throttle posistion sensor
Old Jun 12, 2009 | 06:00 PM
intiractive's Avatar
Default throttle posistion sensor
Ok so i typed this message once, and it said it was too short! aghh i hate that, i get it everytime i post. Anyways.
So i was flipping through the FSM trying to diagnose like a doctor, my 1-3k hesitation problem. (i already cleaned carbs, new plugs, new plug wires, checked every fuse etc, but thats not my question). I discovered that that open plug on the left side frame rail about half way down is a throttle posistion sensor plug. Mine is open with nothing plugged in. I thought it was a diagnostics port like some older cars have in the engine bay that are left open and hanging there. I know it should lead somewhere to the throttle. I have 2 open plugs on the right handle bar that are male/female connectors, not your plug that you squeeze to remove. I assume thats where it attaches? Is one of them a front brake switch, the other my TPS?
Can anyone tell me where this plug hooks up to, or have a picture? Thanks alot. BTW, this is the connector:
Old Jun 12, 2009 | 08:01 PM
That is the Throttle Position connector. The throttle position sensor is located on the left end of the carburetors. It has a wiring harness that routes down and over to that connector on the left side of the bike. (don't pay any attention to the red circle, that was to show someone where the idle screw attaches). It's in the metal bracket on the left side of this photo near my hand.
You can see the connector and the harness going up over the frame towards the sensor.
Last edited by IDoDirt; Jun 13, 2009 at 08:25 AM. Reason: Added second and third photo.
Old Jun 12, 2009 | 09:23 PM
f3BikeR's Avatar
IdoDirt is correct.
It's only about 1' long from the male connector to where it attached to the carb body. That's where it senses throttle position..
Old Jun 13, 2009 | 05:40 PM
thanks a ton guys!!
Old Jun 13, 2009 | 06:28 PM
Default Doh!
hey guys. thanks for the replies. i appreciate it alot for the help!
upon looking for a connector harness.. i have nothing on the left side of my carbs... i had them off once when i cleaned them, and i shoulda remembered not seeing one doh!
that leads me to believe maybe they're carbs from a different bike? I saw a stamping on each carb, i tried typing this code in in google and tried finding codes for the carbs... but nothing was coming up. tried bike bandit and the FSM.
41AWHF7.
can anyone shed some light?
this is what my carbs look like from the left side of the bike where the connector is supposed to be located. (pictures are clickable thumbnails)
Old Jun 13, 2009 | 10:38 PM
f3BikeR's Avatar
they don't appear stock.
Stock carbs are labeled with "61A" or similar depending on CA model/non CA.
Old Jun 13, 2009 | 11:18 PM
41AWHF7.
Please tell me that you haven't cleaned these carburetors and that you're really talking about some others that you cleaned. Or at least that it was a real long time ago that you cleaned them. OK, off my soapbox now...
Here's the serials you should see on your carbs depending on the years. Looks like yours may be off a F2.
Old Jun 13, 2009 | 11:50 PM
Sand.Man's Avatar
IdoDirt, your bike is incredibly clean. Bravo.
Old Jun 14, 2009 | 05:35 PM
idodirt... i cleaned the INSIDE... not the outside!!!! hahaha. outside doesnt affect performance!! thanks for the info dude, i guess i have to figure out where to go from here. i was thinking all day long... what effect will the TPS being unplugged do to the other electrical **** on my bike? like what does the TPS "talk" to on it? is it possible to run without it?
Old Jun 15, 2009 | 12:41 AM
f3BikeR's Avatar
THe TPS gives info to the digital ignition module.
You may have an f2 motor in an f3 frame or just f2 carbs on a f3 motor but the airboxes are different so i dont know how this all came to be...
