throttle cables
Old Mar 19, 2014 | 10:53 PM
  #21
jblair626's Avatar
Originally Posted by jeason15
okay, im going to weigh in here too. without a doubt, THE TOP CABLE IS THE PULL SIDE (TWO NUTS), THE BOTTOM IS THE RETURN SIDE (ONE NUT, NON-ADJUSTABLE).
yes I concur
Old Mar 20, 2014 | 06:43 AM
  #22
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
Old Mar 20, 2014 | 10:18 AM
  #23
Fritos's Avatar
Originally Posted by Hootie233
The only thing other thing he could be refering to (other than the handle) is the butterfly valve thing in your carbs. If this is what he is talking about, you need a new mechanic. Replace the cables, make sure the area where the handle roates is clean and smooth.
He's talking about the handle area. I'll try taking a look myself when I get the bike back. What should the handle feel like if I were to disconnect both cables? Should there be any resistance turning the throttle or should it be quick like a hot knife through butter?
Old Mar 20, 2014 | 10:19 AM
  #24
Fritos's Avatar
Originally Posted by RoadiJeff
Hey it was this or create a new thread!
Old Mar 20, 2014 | 10:21 AM
  #25
Fritos's Avatar
Originally Posted by hamlin6
Do you feel proper tension when you twist it? Both throttle cables connect to the same part. There is only one. If memory serves correct, the pull cable is on top.
A good safety tip is to take a sharpie and write a "T" on the nut of the top one and "B" for the bottom one. That's what I do so I don't have to think. :-)
I believe it's proper tension. This is my first bike, and the only bike I've tried before it was the bikes at school.
I'll try your tip when I open her up, thanks for the advice
Old Mar 20, 2014 | 01:11 PM
  #26
jackojeff's Avatar
Okay so im a racer and im not allowed to go out on track unless my throttle snaps shut if its even a little slow then its a no so heres a how to for you guys not sure
Attach cables at slackest settings
At the throttle there is an adjustable nut, turn that to tighten it (righty tighty) as far as possible, there is a standard nut and a very long one do the same for both
Then adjust at the carb side so that there is minimal movent before the butterflies open and minimal slack in the cable
Happy days no more thread revives
Old Mar 21, 2014 | 12:21 PM
  #27
jblair626's Avatar
Great Advice! Thanks Jeff
l-town
Jun 20, 2014 04:20 PM
zellster
Sep 29, 2010 02:42 AM
irocthestreet
Feb 17, 2009 10:33 AM
JDubF4i520
May 20, 2007 03:40 PM
