Temp Sensor with f4i gauges
#21
I'm going to still work on this. I was looking at a digital resistor. It allows you to set specific resistance at certain temps. And you can set up to 100 different "taps". This way you can get extremely accurate if you want.
rothjl749 do you know the correction needed at around the 200 deg mark? I just need some more correction points to dial in. if not I can check. Thanks!
I believe at 220 it was somewhere in the neighborhood of 2600 ohms. I can check when I get home, I still have everything rigged up on the kitchen table. The wife is not too pleased with my science experiment though so I may not have too many days to work on it. I could get a restance value every 5 or 10 deg if you need.
#22
Where will the digital potentiometer get it readings from? This sounds interesting, I would be curious to know how this would work.
#23
#24
edit: The risk of breaking off the temp sensor when pulling the original out is what I'd be trying to engineer away.
#25
Well my thought was to not have to pull out the stock F3 sensor at all. Putting something like this converter will cost like $3-$5 instead of pulling the tank, airbox, carbs, and paying $40-$50 on the 900rr sensor. You also run the risk of snapping the sensor off from what I've heard. It's probably over tightened at the factory....
Once we have all the technical stuff down, it'd be very easy to replicate.
I'm a geek!! I love this shi*t!
#26
Also, is there a risk of these resistors getting too hot and wreaking havoc? By havoc I mean melting wires or just plain failing prematurely.
I know the resistors for my LED blinkers get pretty hot just from 30 second intervals of use far away in the tail from any hot engine components, and there would be constant use on these resistors with the key on.
#27
#29
