Tachometer problems
I sure hope someone can help me, as I have been trying to get this working for a few days now.
I have a 96 f3 that I am putting a aftermarked gauge setup on. It is a cheap one from ebay. Motorcycle Digital Speedometer LCD Gauges Digital Panel Universal Best OFFER | eBay My problem is I can't get the tach to work. I have hooked it up to the green and yellow signal wire that is for the stock tach and nothing. I have tried hooking it up to the coil on all four of the connections and nothing. I have tried hooking it up to the yellow wire coming off the pulse generator and I get signal, and the tach works, but at 1000 rpms it is reading 11000ish on the gauge. I have changed the pulse setting to a couple different settings and get nothing different. I'm not sure about just wrapping the wire around the spark plug wire.. not sure if I would need a special inductive wire to make that work or what. There is only one signal wire for the tach coming from the cluster as well if that makes any difference. If someone could give me some help...id appreciate it! |
The Yellow/Green wire is the source for RPM on the F3. Have you checked to see what voltage you're getting from it ? You'd need a Peak Voltage capable meter to read it. Did the Tachometer work before ?
Yep. Never had a problem with the tach. What voltage should be coming from it?
Originally Posted by Spruytte0717
(Post 1222726)
Seems that's the story I keep hearing. Iv talked to multi people that cant get a aftermarket tach to work on the f3. I have been picking through every forum out there trying to get some info, and there are dozens of threads trying to solve this issue.
I have exhausted every option that I can come up with to get this to work. At this point it seems like I am going to have to go with a different setup. It is odd that so many people have done the f4i cluster swap with not a issue though. Amsoil929 could you give me some details on your setup? I have never torn into a old school 1000. Does it use a single signal wire to the factory tach as well? Also what tach are you trying to install? |
(Post 1223425)
I have exhausted every option that I can come up with to get this to work. At this point it seems like I am going to have to go with a different setup. It is odd that so many people have done the f4i cluster swap with not a issue though. Amsoil929 could you give me some details on your setup? I have never torn into a old school 1000. Does it use a single signal wire to the factory tach as well? Also what tach are you trying to install? I am attempting to run the KOSO gauge. I don't know the model of it off the top of my head . |
(Post 1223353)
Originally Posted by IDoDirt
(Post 1223580)
10.5v minimum using a Peak Voltage meter. You're not going to read that on a standard meter.
Excuse my ingnorance on this topic. |
Just watched a YouTube video (
From my understanding a Peak voltage meter only shows you the max output not the exact current output? |
That video does look like it should work. It is funny though that he's using a Fluke Model 87 meter, which is able to read Peak Voltage (I know because I own one).
AMSOIL929, Peak Voltage is what you're trying to measure, not current so you're good. |
| All times are GMT -5. The time now is 02:01 AM. |
