Stock chain and sprocket sizes?
Old 04-01-2008, 04:13 AM
gerharddvs's Avatar
Default Stock chain and sprocket sizes?
Can anyone please tell me what is the stock chain and sprocket sizes for a '95 F3?
Old 04-01-2008, 04:21 AM
KidCr3nshaw's Avatar
Default RE: Stock chain and sprocket sizes?
14/43 sprockets, 108 link chain.
Old 04-01-2008, 04:26 AM
gerharddvs's Avatar
Thanks. What typeof chain ex: 520, 530 etc
Old 04-01-2008, 04:40 AM
Sorry, I believe stock is 530. Go with a 520, 600's don't need 530's.
Old 04-01-2008, 05:30 AM
gerharddvs's Avatar
The stock one gave me about 25000 miles (which is amazing) so I'll rather stick with 530 cause the 520 probably won't last that long. Mine has a 15 infront and a 43 at the back
Old 04-01-2008, 05:37 AM
Whoops - typo. 15/43 is correct.
Old 04-01-2008, 12:03 PM
kjohnson's Avatar
Nope,not if you use a good 520 (DID,EK,etc etc).I have a 520 on the racebike that's still holding up well (knock on wood).
Old 04-01-2008, 02:43 PM
pr0jktmayhem's Avatar
could have sworn somone toldme to buy 525 chain. and i did will this fit on stock sprockets?
Old 04-01-2008, 02:53 PM
Probably not, buddy. I'm trying to remember - I could swear it was a 530 but it's been so long man.
When you get your chain, it should slide right onto the sprocket with no wiggle room side to side. If it feels like you have to push it onto the sprocket then you're going to have to return it (or find someone here who might need it).
Whatever you do don't force that chain on there - good luck!
P.S. Just sos we all know - chains are measured with two numbers that make up one number. The first number (5XX) represents the distance between rollers. The second numbers (X20) represent the width of the chain. So a 530 is wider than 525, etc. Generally 530 chains are really only needed for liter bikes as there is much more torque placed on the chain. Any 520 from a reputable manufacturer should provide you with at least a complete riding season (should be considerably more)- depending on how well you take care of it.
Old 04-01-2008, 02:58 PM
Just FYI, those plates actually relieve some premature wear on the entire rear-brake system. In the absence of those spacers you're requiring the caliper hold more fluid which can cause seals and rings to go bad prematurely.
Now - when I say prematurely, I don't mean tommorrow. Calipers need rebuilt like what - maybe once every fifteen years or so, lol? Lack of those spacers prolly know maybe 3 years off of that time. So it's really just as Pace said - up to you.
Just thought I would throw that out there!
Quick Reply: Stock chain and sprocket sizes?
