Still blogging at WOT
Old 07-15-2008, 09:38 AM
njdjh2o's Avatar
Default Still blogging at WOT
Changed the fuel pump and filter, cleaned the spark plugs adn bike still bloggs at WOT. But if I slowly accelerated the bike performs normally.
I changed everything, I mean everything on the bike. This didn't start until I shorted out the bike, before that is ran perfect.
I am so lost, I guess it will be going to the dealer. ARRRRRR!!
But, revs perfect when in neutrel or clutch in.
Old 07-15-2008, 10:03 AM
redzintimidator's Avatar
Default RE: Still blogging at WOT
thats strange.....
yea you stumped me on this one...lemme think about it
Old 07-15-2008, 12:43 PM
Alright newb question what is WOT?
Old 07-15-2008, 12:48 PM
njdjh2o's Avatar
Wide Open Throttle, that is when you got the throttle as far as it can go. If you keep it at WOT for any long period of time, you should be getting a ticket.
Old 07-16-2008, 09:48 AM
johnyquest's Avatar
Same EXACT issues here. Here's my thread. http://www.fireblades.org/forums/hon...ll-around.html
johnyquest's Avatar
That's my thread above. Maybe we can work together if this is what yours is doing.
johnyquest's Avatar
And for some reason, I can only post ONE LINE at a time. I wrote a lot more. This is annoying as HELL.
Old 07-16-2008, 10:02 AM
LOL WOT. Didnt think of that. From my dirt bike days we called it 6 and open.
Old 07-16-2008, 10:59 AM
Northernfirepower's Avatar
I was gonna say "Warm operating temp"
A buddy of mine had a similar issue with his '96 GSXR, and it turned out to be bad connections in the main wiring harness connectors. He went thru and rewired everything up in front and all his problems went away.
Maybe just look at some of the primary connections and make sure their not melted or corroded bad.
Old 07-16-2008, 04:49 PM
njdjh2o's Avatar
My bike was running fine, until I jump started the bike with the car running, which burned out every electrical/sensor on the bike. Replace everything that is connected to the wire harness.
The weird part is I can get it past 8k upto redline in 5th gear, but it still boggs (mis-fires), but, once I shift to 6th gear it won't past 8k. If I tuck downit probably goes upto 8.5/9k. At this point I am pushing 90/95 MPH, but that is the fastest the bike goes.
I am so lost at this, never had this problem on any of my bikes.
