Stator to Regulator/Rectifier: Best Approach for Direct Connection
Old 05-11-2014 | 03:53 PM
SmokinJoes's Avatar
Default Stator to Regulator/Rectifier: Best Approach for Direct Connection
Fellow SeaBarfers,
From the wiring diagrams of the CBR600F3, I can see that the stator outputs to the regulator/rectifier.
From what I see physically, the stator wires make a stop at the connector box beneath the fuel tank. I presume from there that it then goes to the regulator.
I would like to use 12ga wire and connect it direct to the regulator/rectifier. But what do I do about the connector box? I see 5 different sets of plugs going into it.
Old 05-12-2014 | 09:40 PM
dad0507's Avatar
You should be able to run the three yellow wires directly from the stator to the regulator.
Old 05-13-2014 | 05:11 AM
jackojeff's Avatar
the stator wires go up to a connector the wires from this then go to the reg rec with an addition 2 wires there
you can take the first connector off and solder the wires together
its an easy job and stops a build up of heat in the connector it does mean if you need to remove your stator you have to cut the wires or unsolder them
Old 05-13-2014 | 04:20 PM
SmokinJoes's Avatar
Thought so! Excellent.
medicbaldwin
05-21-2013 10:27 AM
Jay Sighmon
11-12-2012 09:37 PM
Jay Sighmon
06-20-2011 07:49 PM
lovemy-cbr
08-12-2009 12:08 PM
dketelsen
09-29-2006 11:31 PM
