Sprocket Question
Old Feb 11, 2008 | 08:25 PM
mhonda98's Avatar
Default Sprocket Question
I've been running a -1/+5 sprocket setup is there anyone that can tell me how far off is the mph on the speedo campared to the stock setup.Thanks in advance.
Old Feb 11, 2008 | 09:34 PM
Default RE: Sprocket Question
It wouldn't be that difficult to calculate with some of the spreadsheets that are out there. But that would be just a calculation. My suggestion is try to get your hands on a portable GPS. You can then see exactly how fast you're going in any particular gear. Motorcycle speedometers are inherently inaccurate.
Old Feb 11, 2008 | 09:38 PM
mhonda98's Avatar
I wasn't going for exact I was looking for some close.What spreadsheets are you referring to.
Old Feb 11, 2008 | 09:44 PM
Check this sitefor a download.Your shop manual has the values you need to fill in for the F3 as far as gear ratios.
Old Feb 11, 2008 | 10:09 PM
kwong2001's Avatar
I've got a spreadsheet if you need one. It's modified to show the differences in mph after changing sprockets.
Old Feb 11, 2008 | 10:25 PM
mhonda98's Avatar
Yeah I would like to check it out Kwong.Thanks
Old Feb 14, 2008 | 08:38 AM
F3Rider's Avatar
im currently running -2, +5 and heres my speedo readingcompared to actual (This was clocked using another vehicle).....
Indicated 35mph on Speedo.....Actual--25mph
Indicated 45mph.....Actual--35mph
Indicated 70mph.....Actual--55 mph
Indicated 90mph.....Actual--70mph
this gives u a rough idea how far its off on my bike......the faster u go (or higher rpms)....the farther off the Speedo is....as u can tell ^^
Old Feb 14, 2008 | 08:47 PM
FNQuickF2's Avatar
I'm kinda confused...Isn't the speedo running off the front tire? If I'm correct, then it wouldn't matter what sprocket combo you have, only the engine RPM's tell a different story against mph...ie, 7000rpms at 60mph vs 5000rpms at 60mph stock. In either case, the front tire will still be rotating at 60 mph...
Am I smoking some good stuff here or ?
RB
Old Feb 14, 2008 | 09:05 PM
mhonda98's Avatar
No the F3 are an electonic speedo the F2 ran off the front wheel.
Must be some good s**t though.HAHA
Old Feb 15, 2008 | 01:42 AM
shoemjay's Avatar
damn i only did -1front and +2 back and that **** runs high rpms and maxs out i think way to fast in 6th how does it feel having 5+ teeth i really didnt know that could make such a hugh change?
