Spark plugs are fouling.. help!
Old 08-19-2007 | 10:11 AM
tho418len's Avatar
Default Spark plugs are fouling.. help!
My spark plugs keep fouling. What causes this and what can be done to fix this???
Old 08-19-2007 | 11:13 AM
land_warrior.rus's Avatar
Default RE: Spark plugs are fouling.. help!
Get your carbs checked. Check your air filter. Make sure its not oil you get on them.
Old 08-19-2007 | 11:19 AM
dorkbiker's Avatar
Oil fouled or gas fouled?
Old 08-19-2007 | 12:25 PM
tho418len's Avatar
Its more oil than gas.
Old 08-19-2007 | 12:28 PM
marc0011's Avatar
If you can get a clear picture of the individual plugs and post it, we could tell ya right away.
Old 08-19-2007 | 01:01 PM
dorkbiker's Avatar
If it's "more oil than gas," you might be running a little lean on fuel. I had a ZX6 with a bad vacuum valve on the #3 carb which caused it to oil foul plugs. Because the valve didn't open, fuel was leaner on that cylinder which meant I was burning oil more than gas, creating the residue that fouled the plug.
Carbs or EFI?
Old 08-19-2007 | 01:19 PM
tho418len's Avatar
Carbs. The plugs were blackish looking.
Old 08-19-2007 | 06:43 PM
dorkbiker's Avatar
I'd say pull off the carbs and clean them. If it has never been done, they might be all gummed up in the jets making them run lean. Clean the carbs, change the plugs...and check the air filter for blockage...fuel filter too.Before you re-assemble, check the spark and see if it looks strong. If it's strong, ignition is good which would make me lean more toward a fuel issue. Put it all back together and see what happens to the plugs after some mileage.
sportracer07
11-10-2007 12:25 PM
92cbr900
08-27-2007 12:29 PM
CBR900RR_JAPAN
08-17-2007 04:55 PM
JohnnyInsano
01-30-2006 03:03 AM
02-18-2005 11:41 PM
Quick Reply: Spark plugs are fouling.. help!
