Shorty Exhaust - Increase Packing?
RE: Shorty Exhaust - Increase Packing?
Wow that is loud.
Not as bad as a set ofSampson Street Sweepersbut bad enough.
Anyone riding behind you is not going to be very happy thats for sure!
IMHO I would pack the baffle as tight / full as you can get it to ensure their is enough back pressure in the exhaust.
Otherwise your going to damage the motor.
Those short slip on's are to be used on modernmotorcycles that run a cataylitic converter.
Good luck!
Good luck!
i am running thatpipe now (im glad there are others that have been trying it). its really loud, but not obnoxiously loud. I'm sure the D&D is comparable. Also, the decibel levels that are stated on the pipe are when the bike is WOT above 10k rpms or so. Cruising around town is no problem. Everyone has given me compliments on it. i also get a lot of people asking me to rev it. There is absolutely NO packing or baffle, so it means NO back pressure. You have to jet your bike after installing the pipe. all in all, im so happy with it. I saved so much weight (over the stock exhaust), with the jettting ive been getting much more power, and the sound is to die for. a lot of my friends are looking into it and for $80, why not?
Cheers! [sm=icon_cheers.gif]
ORIGINAL: omninate
Glad to hear you are enjoying the pipe!! I got mine for $60 (watch for one of the ebay auctions that does not have a buy-it-now price) - I also figured why not? Sounds like my noise concerns will not be an issue, but back-pressure will be. Conrice, I see in your signature you are running a Stage 1 Jet Kit. Is that the Factory Pro or the DynoJet kit? Also, I have not ever torn into the guts of my F3s carbs - how bad is it to install a jet kit?
Just remember, the real battle is just having to take everything off to get the carbs, after that, its pretty easy.once the bike seems like its idling correctly and revving correctly, take it for a ride. if it has flat spots or bogs down, clean your air filter and play with the pilot screws until it feels right, i suggest leaving the needles in the middle groove. ENJOY![sm=gears.gif]
ORIGINAL: Conrice
Just remember, the real battle is just having to take everything off to get the carbs, after that, its pretty easy. once the bike seems like its idling correctly and revving correctly, take it for a ride. if it has flat spots or bogs down, clean your air filter and play with the pilot screws until it feels right, i suggest leaving the needles in the middle groove. ENJOY![sm=gears.gif]
