SHOCK Questions
Old Feb 23, 2007 | 02:30 AM
96F3's Avatar
Default SHOCK Questions
Hey All,
Looking to upgrade / swap out my 96F3 shock for a F4 , F4i one.
Questions are ,,, What year , years , shock will fit my 96 ?
Are the F4 and F4i the same size ?
What's the difference between the Red color and Yellow color springs ?
( Or is red a certain year ,,, and yellow another ) .
p.s. ,,, I DO want to raise the rear some .
THANKS for ALL who reply !
Old Feb 23, 2007 | 10:39 AM
jbreit's Avatar
Default RE: SHOCK Questions
the F4i shock is longer as you already know... it raises the back end quite a bit....enough that the back end is a little less stable at speed, but it turns in fast. You'll have to grind clearance in the pivot to have access to the rebound adjustment screw.
not sure about colors....I suspect its part of the paint scheme.
Old Feb 23, 2007 | 01:37 PM
racer212's Avatar
Dont hold me to this, but I think the different colors are different spring rates. The F4 and F4i had slightly different linkages IIRC hence different springs.. like an F2/F3.
Old Feb 24, 2007 | 02:05 AM
96F3's Avatar
jbreit ,,, Is the F4i shock longer than the F4 ?
Old Feb 24, 2007 | 05:19 PM
jbreit's Avatar
Racetech shows the same spring rate from 99 to at least 01
Old Feb 27, 2007 | 03:23 AM
Hennessy's Avatar
look for the hyper pro progressive racing springs for the f3
Old Feb 27, 2007 | 07:50 AM
pacemaker's Avatar
Bummer, I thought "Shock Question" may ave been something a little bit more shocking.
The_Prince_NR
Apr 19, 2011 11:47 AM
MikeInCtown
Jan 16, 2008 06:30 PM
