Replaced Battery, now bike won't turn on
I hadn't ridden my bike(95 F3) in a week or two and it was pretty cold when i tried to start it last. battery went dead just as it sounded like it was going to fire up. I pulled the battery, charged it, put it back in and now when i put the key in the "ON" position i get no headlights or gauge lights. i checked the battery voltage and its good, the battery is brand new as well. I pulled the sub fuses up front and tested all of them and they are good. The only one I haven't checked is the main 30 amp fuse. All the connections are tight on the battery. Any tips on how to get to the main fuse? I know its in front of the battery but I can't seem to find it. I have the repair manual but it doesnt show how to get to the main fuse. Does the battery box need to be pulled to get to it? And yes, I double checked I have the battery hooked up right. ie. not backwards. Thanks in advance for any tips.
-Drew
-Drew
definitely sounds like the main fuse. damn i forget where the main fuse is on the f2 but if you give me a sec............
http://www.cbrextreme.com/downloads/...manual-14.html
ORIGINAL: drew999
awesome, thanks to both of you for the help. Got the fuse out and it was definitely blown. popped the new one in and it started right up. now it would only stop raining...
mcmahan87
06-05-2013 05:13 PM
Survivalism
07-20-2011 01:33 PM
elivancho
11-30-2010 08:28 AM
