removed pipe and fluid came out and unsure how scarred i should be
Old 10-28-2010, 10:42 AM
jackojeff's Avatar
Question removed pipe and fluid came out and unsure how scarred i should be
ok so im removing my carbs to put restrictors in whilst its stripped to the frame iv been trying for 2 days and no luck as i dont have long enough srew driver (my aircraft engineer dad took em to work ) anyways so im having bad time with carbs then i pulled a pipe off that had alot of evaporated petrol and it went straight up my nose so i was quite dissy then i pulled a pipe (it was in the way of a screw) out of the cylinder and traced it bak to a hub on the left neer the gear shifter think may be radiator fluid.
how worried should i be that i spilt like 2L of the stuff
and how easy is it to replace
Old 10-28-2010, 12:17 PM
kerosene's Avatar
This thread is full of "Huh?!"
Really long sentance btw.
After re re re re reading, I think I know what you mean... you pulled off a tube that goes into one of the cyl's. if it's green liquid then yes, it's radiator fluid... go to a Honda dealership and buy more fluid to replace, it's on the right side of the bike infront of the shock (white reservoir.)
Old 10-28-2010, 03:45 PM
jackojeff's Avatar
sorry for bad sentence, was still rather intoxicated from the petrol. yes i know were to fill it after feeling better i looked again. any guesses on prices?
*insert c were aplicable as its not working very well
Old 10-28-2010, 04:19 PM
kerosene's Avatar
Hmm, It's around 15$ for a gallon or so, I can't imagine you spilled 2L, that would be he enire reservoir.
Get the radiator fluid from Honda, I will not recommend any other fluid, it just isn't the same
Old 10-29-2010, 12:52 AM
Michaud85's Avatar
dude what color was the fluid.... radiator fluid doesnt usually make me dizzy.... unless coolant and radiator fluid arent the same thing
Old 10-29-2010, 08:52 AM
jackojeff's Avatar
Noo u misunderstood!! I took a petrol pipe off my carbs and took alot of petrol fumes up my nose (i took a breath as the pipe came off) and that made me dizzy causing stupid mistake of pulling rad pipe off
Old 03-21-2011, 01:07 PM
jackojeff's Avatar
ok so is rad fluid and coolant the same bought some halfords anti-freeza/coolant to stick in my 50cc 2 stroke then got asked by my dad why i hadnt put it in my bike and was all confused so it can go 108C max -34c min 2 year life and aparently is "safeguarded" anybody used it or should i only use it on my 50cc (selling so dont care) and do i have to use distilled water or are people just going over the top when saying that
Old 03-21-2011, 01:52 PM
Joe 96 CBR F3's Avatar
I use Coolant, any brand, dosent matter to me. If you wanna make it really easy you can buy the pre mixed stuff and not have to worry about deluding it. I have never had any problems with it. Thats just my experience though.
Old 03-21-2011, 02:13 PM
jackojeff's Avatar
Can i just drain old mix and fill some say to purge it 3-4 times but that effort and i dont wanna
Old 03-21-2011, 04:17 PM
MadHattr059's Avatar
Ok, gotta say this! That is almost exactly the formula I use to make my wife easy. Get her some of the pre-mixed stuff Aafter I get that in her, I can delude her with what a sexy guy I am! lol
Ern
Quick Reply: removed pipe and fluid came out and unsure how scarred i should be
