Rejetting question
Old 03-23-2011 | 01:10 PM
Mrmanr's Avatar
Question Rejetting question
Just wondering if i have a uni and yoshi slip on do i need to rejet carbs? Does anyone have this same setup? Would paper element be better? Im taking carbs back off to reclean again, what is the best set turns for pilot screws? Thanks guys!!
Old 03-23-2011 | 07:11 PM
No need to rejet and a paper OEM element is best for that type of setup.
This is straight out of the shop manual. I'd be interested in how others would interpret this.
Would you read it as 1 and 2/4 (which is 1.5) turns out.
One to Two Quarter turns, meaning .25 to .5 turns out.
Japanese to English translation is funny sometimes.
Old 03-23-2011 | 07:33 PM
reddog952's Avatar
When I bought my F3 it had a Yoshi slip on, stock jetting & oem air filter. I put a K&N air filter on it. It seemed to run about the same but had a flat spot around 5 or 6k (going on memory). I then installed a Dynojet kit. The difference was night and day. The bike was much more lively..Prob. not much power gain, but much more responsive. Look at the shape of the needles, plus you enlarge the vacuum hole, plus put new springs it. Carbs prob. getting 30% or more air with the high flow filter. This was the one mod that really made a noticeable differnce. I have -1, +3 sprockets, +2 ignition advancer, neither of these 2 mods did anything compared to cleaning and rejetting.....
Old 03-23-2011 | 07:36 PM
Mrmanr's Avatar
Thanks on that! My manual says 2 1/8 turns out Just curious .. How many turns is a good start point ?
Old 03-23-2011 | 07:45 PM
reddog952's Avatar
I dont remember. I did everything exactly as the instructions..Reassembled and never have touched them again..Been almost 2 years......It was my first time rejetting carbs. I was a little intimidated at first. I used a carb cleaning tutorial that I found on here somewhere. It made it quite painless. The biggest pain is the throttle cables. I accidentalt kinked my throtle return cable. Mt throttle doesnt snap shut quite as good as it used to. Take your time with those. I was impressed by the kit.
Old 03-23-2011 | 07:46 PM
reddog952's Avatar
Old 03-24-2011 | 02:41 PM
Mrmanr's Avatar
Thanks for link! I might look into rejetting if mine doesnt already have it, will find out tomarrow when tear em apart again. How much do they run? And whats the best way to clean valves? When i took my Carbs off i look down in motor and valves had build up on them. Thanks again!
Old 03-24-2011 | 07:52 PM
reddog952's Avatar
Jet kits run around $100. I would put a high flow air filter in before you rejetted, imo.
ThisisMickey
05-30-2007 09:58 PM
ThisisMickey
05-27-2007 08:18 PM
ThisisMickey
01-24-2007 01:47 AM
gromay
09-14-2006 11:43 PM
c11x
03-20-2005 06:02 AM
