Rectifier
Old Feb 11, 2011 | 08:46 PM
Tremar's Avatar
Is it okay to go with another stock f3 since I dont plan on keepign this bike more than another 2 years? or a GSXR one?
Old Feb 12, 2011 | 08:27 AM
reddog952's Avatar
I used this "flow chart" when mine went out. The oem r/r usually gets hot a springs a small leak.
http://www.offwidth.co.uk/bike/gener...lt_finding.pdf
Old Feb 12, 2011 | 08:32 AM
reddog952's Avatar
Link below shows my old r/r and the new one. You can see where the old one got hot and melted through...
http://www.facebook.com/album.php?id...933303&theater
Old Feb 12, 2011 | 11:44 PM
Tremar's Avatar
I cannot view that picture as I am not your friend, can you put it on photobucket or something
Old Feb 13, 2011 | 05:09 AM
reddog952's Avatar
I need to set up a photobucket account or something.. I wouldnt go stock. A new one is $170. I think I paid around $60 for the one in the picture (Ebay).
Attached Thumbnails Rectifier-2009-08-15-001.jpg   Rectifier-2009-08-15-016.jpg
Old Feb 13, 2011 | 11:01 AM
marc0011's Avatar
You should also check the connectors in the charging circuit because they get cooked when the RR goes out. If you don't check them and they are cooked, they'll cause the new to burn up prematurely due to the excess resistance. These RRs are a POS from the factory because of the electronic components (shunt vs. mosfet). I changed mine up to an RR that is out of an 08 R1. I also changed the wiring in the bike harness to a larger gauge (12 to 10) because for some reason Honda that it would be a great idea to run different gauges of wire. When coming out of the stator, it's 10 gauge and then changes at the stator plug to 12. This can also create excess resistance.
graygeezer
Jul 31, 2011 02:33 AM
cbrsingleside
Apr 28, 2010 08:55 PM
rkgjr1981
F2 Tech
Apr 13, 2010 11:46 PM
falieson
Jan 22, 2010 12:40 AM
Junior
Aug 27, 2006 01:25 PM
