Rebuilding my Superbike F3
Old Mar 11, 2011 | 12:00 PM
bigbob65's Avatar
Default Rebuilding my Superbike F3
After having engine trouble at MsrH ( lost 6th gear) I decided it was time to drag my Spare f3 chassis from behind the garage and start building it into a full on Superbike that would have been a killer if they had world supersport back then. ( Thank you Gill Eperson for the chassis, just needed a wiring harness, he gave me a clmost complete chassis)
Soo, I stripped it down, and cut off all non essential tabs off the frame. and cut alot off the rear subframe. I lost 7 lbs off the Frame.
Then I sent it off to Tony to have some nice paint work done
For now, that is all. The motor is mostly finished. Need a new cylinder head, then have it ported and polished, and install the goodies. Bottom end has Carrilo rods, Ape crankshaft, Polydyne coated Transmition gears and clutch assembly, Ebc clutch kit, Not flywheel, and weisco 1st over pistons.
Im hoping for 115 at the wheel on half 93, half c12, 120 on u4.
MOre to come tomarrow.
Old Mar 11, 2011 | 01:25 PM
hioc1098's Avatar
I like it, so far.
Old Mar 12, 2011 | 06:54 AM
spicymeowmix's Avatar
Official Welcome Crew Spicy Cat
post up as many of these pictures as you can.
i wanna see the whole progression!
Old Mar 12, 2011 | 11:39 AM
bigbob65's Avatar
will do.
Old Mar 17, 2011 | 01:21 AM
bigbob65's Avatar
Not sure if im going to try and paint the wheels, or if Im going to give them to tony.
Also need to send the shock to Rodger for some work soon.
Robmarz
Jan 13, 2013 04:46 PM
trabich
Apr 10, 2012 05:51 AM
Assortedqtip
Feb 8, 2012 10:16 AM
02f4eyeguy
Jun 28, 2009 01:13 PM
guyomatic
Mar 24, 2008 03:25 AM
