R1 Tail on my 98
Old Jun 26, 2010 | 02:59 PM
  #291
dsnow77846's Avatar
just bought an f4 spring i hope that lifts of the tail
Old Jun 26, 2010 | 07:20 PM
  #292
dsnow77846's Avatar
and is it ez to install?
Old Jun 27, 2010 | 06:57 AM
  #293
STREETFIGHTER88's Avatar
It will lift the tail yes that's what I'm using on my f2 to lift the rear it lifts it about 2 inches and to install it u just have to remove 2 bolts swap them over then put the 2 bolts back in it's easier if you take the tank and tail off though.
Old Jun 27, 2010 | 03:36 PM
  #294
dsnow77846's Avatar
hey what tank is on ur bike and is it a direct fit?
Old Jun 28, 2010 | 09:45 AM
  #295
Its a 2000 CBR 600 F4 tank and i just needed to make a small bracket for were it mounts at the front as the F2/3 tank uses 1 hole and the F4 tank uses 2 holes.
Old Jun 28, 2010 | 12:52 PM
  #296
dsnow77846's Avatar
does it hold more gas? and once i find a way to hold my tail up im going to install the shock
Old Jun 28, 2010 | 02:36 PM
  #297
tpgpz's Avatar
Default Holding the tail up...
This is what I do:
Remove the tail plastics. Get a sturdy step ladder. Straddle it over the bike with the bike on a rear stand, if possible, otherwise have some one hold it straight up. Use some ratchet straps to lift the bike up off the ground connecting to the subframe and then to the ladder. Make the change, then reassemble. By the way, it also helps if you have it on a front stand to keep the front end from moving on you.
Might sound a little redneck, but it works. Anybody have anything better?
Old Jun 28, 2010 | 03:14 PM
  #298
yer it holds more gas, couldnt tell ya how much for sure but ive heard people saying just over a gallon.
I personally think it makes the bike look even better than a tail swap does its shapped totally different to the ****ty F2/3 tanks.
Old Jun 28, 2010 | 03:42 PM
  #299
tpgpz's Avatar
Ok...stupid question of the day, I am sure. The F2/F3 petcock is manual. The F4 is vacuum, I believe and I am sure you can tie it into the F4i guages to get the reserve light to work. How do you hook it up to the vacuum system? Or do you still use the manual one from the F2/F3? I would be curious to see a pic of the bracket you made for the tank if you have time.
Old Jul 1, 2010 | 02:58 PM
  #300
999 Customs's Avatar
Good question...
