Quick Q - How Much Fork Oil?
Old Jul 4, 2010 | 03:39 AM
CaNsA's Avatar
Default Quick Q - How Much Fork Oil?
Hi guys,
As stated, how much in for a cbr600f3/fs 1995? the forks with the screw on the top. Im about to drop my forks for a rebuild but cant get a definitive answer.
cheers
Old Jul 4, 2010 | 11:19 AM
moostadon's Avatar
just done my 98 f3 its 15.5 ounces
Old Jul 4, 2010 | 11:22 AM
moostadon's Avatar
thats right out of the repair manual and be sure that u put exactly the same amount in each leg its critical
Old Jul 4, 2010 | 03:44 PM
CaNsA's Avatar
Cheers mate.
Been a bit of a **** day today
Get the bike in the garage, up on the axel stands. Remove the front wheel, no probs.
Drop the forks, no probs.
drain then remove the internals, seperate the forks and start to clean them.
Go to insert the new internals only to find they are about 3" shorten than my existing ones.
Im livid. They were advertised as fitting a cbr600f3/fs
So i have replaced the seals and bushes and im using the original internals.
Put the new bearings in the front wheel, twas a good idea putting them in the freezer when i got home form the boozer last night. they slipped right in with a bit of help from a lump of wood and a hammer.
So, im gonna send the internals back, and build the front end back up tomorrow when i get home from work.
/me heads off to ebay to file a dispute......
Peace out
Old Sep 25, 2010 | 06:11 PM
Speedemon636's Avatar
So the 15.5oz is for both or one? And what weight is good? 10? Bike is a '95 F3 btw.
Old Sep 27, 2010 | 01:59 PM
dcaldwell's Avatar
fluid volumes given are for each fork. The Pro Honda Suspension Fluid ss 8 is 10W.
Old Sep 27, 2010 | 04:43 PM
Awesome! Thank you very much! The manual I have is for the F2 sadly.. Came with the bike.. So I don't want to base important things like that off an F2 for my F3 lol
Old Sep 28, 2010 | 02:25 AM
dcaldwell's Avatar
https://cbrforum.com/forum/stickies-91/online-manual-112265/
you can download a pdf of the F3 manual for free..
Old Sep 28, 2010 | 07:49 PM
plumber_rob's Avatar
When pouring in the new oil, the measured height of the oil level is more important than the number of ounces poured. Forks need a certain amount of air space in the fork since oil does not compress. The proper air space helps prevent fork seals from blowing out. Too much oil can blow the seals when landing wheelies or hitting very large bumps. Also remember to pump the damper rod up and down after adding about 1/3 of oil to bleed the air out of the lower part of the fork.
Old Sep 30, 2010 | 04:29 PM
SLORider18's Avatar
for the f3 95-96 oil level is 117 mm from the top, 96-up is 120mm. pump the internals to get the air out and measure. i did mine a few times due to blown seals.
