Problems shifting into gear
Old Jan 25, 2007 | 11:20 PM
Fatboy's Avatar
Default Problems shifting into gear
I swapped out my rearset for another stock piece, because the one on it was bent up and the bolt was stripped causing the shifter to wiggle. Anyways, i got it all hooked up and I can shift through all the gears half the time, and then sometimes it either won't change gear at all, or won't come out of neutral. Also, when downshifting from 2nd it goes straight into neutral, not sure if it's supposed to do that. The bike isn;t running right now, so I'm just shifting with the bike off and parked in my garage. Maybe it has to be running to function properly? I'm thinking I need to adjust the shift linkage or something... hopefully it's nothing internal.
Old Jan 26, 2007 | 01:04 AM
blkpitbull's Avatar
Default RE: Problems shifting into gear
It usually wont shift but up to second with the bike off. Shart it up and try it. If its still "hard" to to shift up or down, you might need to adjust the shift rod. It may be set in longer or shorter position sinceyou took it off.
Old Jan 26, 2007 | 01:15 AM
Fatboy's Avatar
Ah, yea I was thinking the linkage might be a hair too short. The new one I bought had a linkage about 3 inches too long, and a different bracket to mount to the tranny. So i took the original linkage off the put it on my new rearset. Turns out it wasn't perfectly adjusted, so I had to shorten it a few turns. I guess just go back and mess with the linkage length?
Old Jan 26, 2007 | 01:10 PM
blkpitbull's Avatar
Cool, glad you figured it out![sm=icon_rock.gif]
EViR
Aug 31, 2012 06:56 AM
TommyHammond
Apr 18, 2012 10:33 PM
bluerrchik
Mar 24, 2008 12:24 PM
jester61
May 15, 2007 12:16 PM
oliversta
Jul 7, 2006 06:52 PM
