Problem with front blinkers
Old Apr 8, 2011 | 07:31 PM
b.rinner's Avatar
Default Problem with front blinkers
My front right blinker wont blink. It lights up steady then when i indicate...it turns off while the instrument panel light and the right rear is blinking. The left side works just fine.
Ive seen this problem before on other things (not the moto) but i cant remember what it is that is causing this.
Sidenote: I have the wrong (higher) amp fuses in place (all except one are too high)......i should definately get the correct (lower) amp fuses in...correct?
Old Apr 12, 2011 | 09:24 AM
b.rinner's Avatar
nobody?!?!? wow, over 40 views and not even a guess....well thanks for at least not giving me lame ideas. I guess ill just wait til i replace the upper cowl fairing and just put in OEM blinkers.
Old Apr 12, 2011 | 11:49 AM
tjay's Avatar
Not 100% sure what your trying to say in your post.
When you flip the turn signal on what exactly happens?
The fuse size isn't going to cause it not to blink, although you should put the correct size in their.
Old Apr 12, 2011 | 08:01 PM
TommyHammond's Avatar
My rear signal stopped working, and it ended up being a disconnected ground wire.
Old Apr 13, 2011 | 08:15 AM
b.rinner's Avatar
well, the light is on when the bike is one...thats a given......when i flip the switch....the front blinker light actually goes out while the indicator blinks and the rear blinker light blinks.
Old Apr 13, 2011 | 09:40 AM
Mrmanr's Avatar
Get some new bulbs.
Old Apr 13, 2011 | 01:27 PM
b.rinner's Avatar
tried new bulbs....same problem. light comes on.....when i "ask" it to blink, it shuts off while the instrument indicator and the rear light are blinking.
Old Apr 13, 2011 | 07:42 PM
daddywilson's Avatar
if its aftermarket signals then you have the wrong wire hooked up there should be 3 wires and you use 2 when doing new signals. if you hook up the wrong hot wire it is used as a parking lamp or indicator use the other one and its a blinker.
Old Apr 14, 2011 | 08:24 AM
b.rinner's Avatar
hhmmmm, that might work, ill have to see if i can do that.
Old Apr 25, 2011 | 01:07 PM
b.rinner's Avatar
had a guy from the dealer take a quick look (b/c this is my first bike so i wouldnt know what i was looking at wrt aftermarket blinkers) and he showed me that one of the wires wasnt attached anymore so we are pretty sure that is the problem. Whenever it stops raining here in Ohio (aka...never) ill pull the fairing off and see if i can "put the wire back on".
