-   CBR 600F3 (https://cbrforum.com/forum/cbr-600f3-17/)
-   -   Problem with Coolant Temp (https://cbrforum.com/forum/cbr-600f3-17/problem-coolant-temp-62769/)
SHugo Mar 18, 2008 04:20 PM
Since the lay down I noticed that with the ignition on the temp gauge reads middle of normal.....with the bike being DEAD COLD. What did I kill? The temp sensor or the gauge?
IDoDirt Mar 18, 2008 07:04 PM
RE: Problem with Coolant Temp
The shop manual is available for download somewhere on the forum here. In section 18, page 15 it has the procedure for testing the thermo sensor. That should tell you if it's working correctly or not.
SilverF3 Mar 18, 2008 08:18 PM
swap for f4i gauges then see.
SHugo Mar 18, 2008 09:01 PM
ORIGINAL: SilverF3
...yah...I'm going to spend the money on a new gauge cluster just to see if it works....and on top of that...an incorrect gauge cluster[sm=headbang.gif]
SHugo Mar 18, 2008 09:03 PM
ORIGINAL: idodirt
Awesome, found the manual. That will help me tons in the near future.
redzintimidator Mar 18, 2008 10:00 PM
when the bike is off before you start it, and still cold, does it still read that high?
SHugo Mar 18, 2008 10:30 PM
ORIGINAL: redzintimidator
Yes, with Key OFF Engine OFF the temp gauge is at the bottom like it should be. With Key ON Engine OFF and the bike ICE cold the temp gauge reads middle of normal. Messed up connection somewhere?
Correction, with key off engine off it rest NEAR the bottom, not complete on the stop
SHugo Mar 19, 2008 08:05 PM
Anyone?
finley Mar 20, 2008 01:24 AM
Hey where did you find the manual?
marc0011 Mar 20, 2008 11:00 AM
Sounds like you have a bad sensor, bad gauge, or a short. Follow the procedures in the manual to test the electronic components. At this point... it's a process of elimination to see what is causing the problem with your gauge.
