please help getting fed up
Old Jul 3, 2008 | 12:00 PM
kjohnson's Avatar
Default RE: please help getting fed up
If you use an F3 airbox,you will need the fuel pump.
If you use an F2 airbox,you will not need a fuel pump.If you are going this route,I would NOT use a fuel pump.
YouWill have to still run the vacuum line from your cylinder head to the petcock.
Old Jul 3, 2008 | 02:25 PM
f2framef3motor's Avatar
one more question then ill stop [X(] i have three tubes comming out ov the carbs i no all three are air tubes the big one it the mittle i have a spot for on my f2 air box but the two little one on the sides i dont i just left them hanging there should i connect them and run them tho a filter of some sort or plugg them like i said first time messing with a engine and i got this far but i no nothing about carbs
[/align]
