Pilot screw setting help !
Old Jan 6, 2024 | 05:00 PM
MAZON1X's Avatar
Default Pilot screw setting help !
I've read the manual, says 1.5 turns out from seat, but I can't for the life of my complete the whole procedure as stated in the manual. I physically can't get my hand and tool in there to accurately adjust. I could get 1-3 carbs but 4th carb is impossible. Does anyone have a good baseline from experience to set these at ?1.5 out is good till you snap into the throttle,it'll hesitate for a second or 2 then accelerate.
Old Jan 6, 2024 | 05:55 PM
Ed Harris's Avatar
Have you balanced the carbs yet?
Old Jan 6, 2024 | 05:57 PM
MAZON1X's Avatar
Yes I have. Balanced carbs . Have them spot on
Old Jan 6, 2024 | 05:59 PM
Ed Harris's Avatar
OK, that eliminates one possibility :-)
Old Jan 6, 2024 | 06:26 PM
How did you balance them? The issue you have is a classic symptom of out of balance carbs.
it could be other things but that is the most common.
I have found a closer number is 2 full turns. But that is the starting point.
Do you have a tool to adjust the pilot screw?
Old Jan 6, 2024 | 06:32 PM
MAZON1X's Avatar
Yeah, I had messed. Around with the air fuel while bike was running attempting to do the. Procedure, started. Out well but indeed wrong , ended up taking carbs back off and at 1.5 turns out again . I don't have money to buy the specific tool to make my life easier at the moment so trying to do it without buying more stuff . So that's why I'm hoping someone here has a decent starting point other than what I currently have
Old Jan 6, 2024 | 08:55 PM
dannoxyz's Avatar
Pilot screw only adjusts idle mixtures?
Old Jan 6, 2024 | 09:27 PM
MAZON1X's Avatar
The carbs pilots need to be adjusted accordingly sadly. Not a problem with the throttle stop adjuster . Had to clean the carbs and took everything apart . Where they were the pilot screws were set I find hard. To believe we're correct . I have a 2nd pair of carbs where the pilot screws were almost completely out where as the original carbs to the bike were almost all the way in . There is a procedure for these bikes and I sadly just can't get enough room to complete the procedure .
Old Jan 6, 2024 | 11:56 PM
dannoxyz's Avatar
I've used this tool. Saves burnt hands too.
Amazon Amazon
Old Jan 7, 2024 | 07:46 AM
MAZON1X's Avatar
https://www.amazon.com/Adjusting-16-...dp/B0BR3ZK1WX/
Yeah it's a flat head though, these carbs original came with a D shaped pilot screw , I've thought about buying it and cutting stuff off and weld what I need on there lol
