Part missing need help !!
Old Feb 13, 2007 | 08:56 PM
pacemaker's Avatar
Default RE: Part missing need help !!
Sorry about last reply, but my neighbour was at the door, wots happened is that they have probably sold the unit with the wiring attached, not such a biggie, try wreckers, there should be some online to order from. that way it should not be such a hassle, the reg & wiring loom is common to a lot of Honda's (VFR's & so on).
So that can make it easier to track down, the wreckers here, charge about 50% of wot the original costs, plus they may sell it to you with the required wiring attached. You should put out an SOS on this site, maybe someone may have the wiring bits or point you in the right direction. Its a bummer when your so close & this sort of thing happens, but hang in there, it will be worth it.
Old Feb 14, 2007 | 02:52 AM
pointman's Avatar
a rectifier will run you about 35 to 90 bucks on ebay depends on what kind u buy . i replaced mines with a used stock one i got for 20 bucks no probs with it . i would go with a regular oem one on ebay there not to pricey .
Old Feb 14, 2007 | 07:38 AM
mattyss's Avatar
ORIGINAL: pointman
i just looked into that and bid on one! i cant find the other piece i need though anyone know what its called ? also anyone have a picture of what it looks like . not the regulator the other part the wiring loom i cant find much info
Old Feb 17, 2007 | 02:01 PM
Sproutf3's Avatar
Registered Users
if your still loookin for that regulator, i was just thumbin through a j&p cycles catalog and i found them in there part number ZA38386 and its 166.99
Joshua Thompson
Aug 29, 2013 02:03 PM
scorbally1
Mar 23, 2013 07:45 AM
ywg_tinsmith
Oct 9, 2011 11:05 PM
The Unit
Feb 12, 2011 07:41 AM
new06f4iowner
Mar 9, 2010 09:38 PM
