octane rating
Old 03-15-2008, 10:52 AM
sportracer07's Avatar
Default octane rating
I purchased a used f3 and I was wondering what is the best fuel octane to use in it. I also have a ninja and it requires 91 or greater in it I was just wondering if the f3 is the same?
Old 03-15-2008, 10:56 AM
redzintimidator's Avatar
Default RE: octane rating
I use 93 everytime i fill up. I dont know if it requires 93, but i definatly would not go any lower than 91.
Old 03-16-2008, 11:52 AM
Bean600's Avatar
i use 89 and never had a problem
Old 03-17-2008, 11:54 AM
Hell I fill up with 87 everytime and never had an issue!!
Old 03-17-2008, 04:05 PM
shoemjay's Avatar
I dont understand cuz my cars calls for 91 and when i first bought it i tried 89 and that **** sputtered down the street i had to sphifen it out,IT has a 11:1 compression. Then our bikes if im not mistaken have a 13:1 so how is it possable to run such low octane and not feel it w/ such a high compression ratio. I never yet put anything less then 91 but gas is getting up there again if you guys are running 87 w/ no proplem then im ganna start to as well.
Old 03-17-2008, 04:36 PM
Maybe because the F3's are actually 12:1 compression. I run regular gas 87 Octane in both our F3's with no ill effects. Running in my 1000f too.
[IMG]local://upfiles/10297/71E39976BC3A44C8A63E77FDB89E92CB.jpg[/IMG]
Old 03-17-2008, 05:40 PM
hmm...maybe ill start running a lower octane if your not havin any problems...
Old 03-17-2008, 05:53 PM
I run 87 in my bike also and have not had a problem with it at all
Old 03-17-2008, 07:07 PM
It's easy to tell if you need a higher octain. Just run the bike at about35 mph and put it in fourth gear and roll on the gas. If you hear knocking - you need a higher octane fuel. That's that. You don't have to be going slow or at low RPMs per say, but loading the engine at higher RPMs will make it harder to hear.
I've run mine on regular with good results, but usually us mid grade.
Old 03-18-2008, 07:22 AM
kjohnson's Avatar
F2s/3s have lower compression than newer bikes,therefore higher octane gas is a waste of money.Higher octane gasdoes not "clean out " your motor either.Higher octane gas does not yield more power either.Quality of fuel is important ,however.All higher octane does is prevent detonation in higher compression motors (12.5:1 and up).
Quick Reply: octane rating
