not sure whats wrong maybe carbs?
Old 08-21-2010, 02:18 PM
miksane's Avatar
my bike acts the same...intermittantly. i dont ****ing understand it. i got a new fuel filter, problem went away for a week...then came back. i dont understand! whats a solenoid?
Old 08-23-2010, 11:05 AM
espelade's Avatar
A solenoid is basically just an electronically controlled vent. It has 2 inlet sources and 1 outlet. In our case it has one inlet from the front vent tubes and one from the ram air duct. the outlet is to the carbs. from 0-12 mph the solenoid feeds the carbs through the front vents, from 12mph-top speed it switched the feed to come from the ram air duct. If the solenoid becomes dirty or the electrical circuit fails it will attempt to feed the carbs from the small front vents which will result it a vacuum in the bowls- this will force a lean condition and bog the engine down.
Old 08-23-2010, 11:07 AM
espelade's Avatar
Oh I should add that if its acting up intermittently It could be a sticking solenoid or loose/ corroded connection. I would start with the bypass and work from there. Its a common f3 problem.
AdamC
06-26-2016 03:24 PM
KdubyaH
06-02-2016 11:56 AM
jizzy
09-02-2010 11:21 PM
SchiraF4I
04-05-2007 05:33 PM
a1yola
11-15-2005 08:23 PM
Quick Reply: not sure whats wrong maybe carbs?
