no clocks = no go
Old 11-03-2009, 02:58 PM
bullimore's Avatar
Default no clocks = no go
anyone know how to make f3's run properly when the clocks are unplugged ?? been searching for aegis and still no solution. any ideas ??
thanks
Old 11-03-2009, 10:20 PM
Chetsnut's Avatar
Hey Bulli,
I'm in the same situation. My bike is now rebuilt after taking a good hit to the front end, but I haven't decided if I want to convert to F4i or get stock gauges again. In the meantime, I'd like to fire up the bike. Anyone out there have some insight?
Old 11-05-2009, 11:23 AM
bullimore's Avatar
alrite man, i might of found the answer ill keep u posted when i find out if it works
Old 11-05-2009, 06:11 PM
Chetsnut's Avatar
You would officially be my hero!
Old 11-06-2009, 01:56 AM
ajzcamaro's Avatar
Stupid question but what clocks do you speak of? Bc my f3 does not have a clock that I know of.
Old 11-06-2009, 12:06 PM
blakesgst's Avatar
I believe he is refering to the gauges.
Blake
Old 11-10-2009, 11:21 AM
STREETFIGHTER88's Avatar
Let me get this right you guys are removing you speedos and your bikes wont start ????
I took min off today as i've started to streetfighter the bike and it started up fine :S
http://www.facebook.com/album.php?ai...6696743&ref=mf
Old 11-10-2009, 12:17 PM
bullimore's Avatar
Talking
Hi streetfighter88, its not that it wont start is that it doesnt run properly after 2nd gear it bogs down & dies.
Chetsnut - Ground the solid pink wire going to your gauges & you should be running as normal worked for me.
Old 11-10-2009, 12:46 PM
Chetsnut's Avatar
Thanks guys,
Yeah, I've been reading up a bit and the cause seems to be from the air control valve solenoid not switching over at 12mph like it should. Nice write-up here:
https://cbrforum.com/forum/cbr-600f3-17/fixed-flat-spot-5k-rpm-101283/
(third post down shows that his speedo is broken, causing this problem)
Old 11-10-2009, 12:50 PM
chuckbear's Avatar
It's probably your ram air solenoid not opening. I have read somewhere that there is a pink wire you have to ground I believe?? Try a search, I think I've read something here on the topic before...
edit: Chestnut beat me to it.
Quick Reply: no clocks = no go
