No Balls
Old May 20, 2011 | 10:35 AM
Cinderfella's Avatar
Default No *****
About a month ago I fried the ECU on my bike, she would only run on two cylinders but both of the coils were good. I have been away at school and just got a chance to put the new ECU on the bike and she now runs on all four cylinders, and when it's in neutral she revs like normal, but as soon as it is in gear or placed under a load, the bike has no ***** (compared to what it did before this whole issue). My bike is on a gravity feed system so the fuel pump is not the issue. Anyone have any other suggestions? I'm trying to get her fixed before the end of this weekend so I can bring her back down to campus for the summer. Between this weather and ECU I've had no luck this season.
Thanks in advance
Old May 20, 2011 | 11:53 AM
SmokinJeff's Avatar
What do your plugs look like? Good spark, clean air filter, then you've got fueling issues.
Old May 20, 2011 | 07:08 PM
Will.Bass's Avatar
could possibly be that from sitting, the carbs gummed over. you could try some seafoam. but id pull em off, give em a real good cleaning, check the plugs that weren't firing cuz they could be fouled out, clean em or replace, and cut her loose...
Old May 21, 2011 | 02:53 AM
spicymeowmix's Avatar
Official Welcome Crew Spicy Cat
+1 good place to start.
fishfryer527
Apr 7, 2008 05:50 AM
fishfryer527
Mar 24, 2008 08:18 AM
mattyrides07
Jun 8, 2007 04:55 AM
ImmaSquashYou
Apr 23, 2006 11:24 PM
dlbinford
Jul 19, 2005 07:48 PM
