New problems on the F3
Old Nov 8, 2007 | 04:37 PM
Beksooh82's Avatar
Default New problems on the F3
So i posted earlier regarding how the bike wasnt starting, and after replacing the fuel filter the bike started up. Now comes a new problem. I set the idle valve to high, above 3000 rpm because it kept stuttering out when it fell beflow 3k. I took it for a ride and whenever i slowed the bike down the bike would fall flat and die. So then I kept revving it to keep it alive, but every time i put it into gear and the rpm fell the bike would die again. Theres absolutely no problem with acceleration, so it makes me believe its not a fuel problem. Also when i have the choke on the bike stays alive, but when i push the **** away from me to turn it off, the bike turns off. Surprisingly the only way I could ride the bike was when the choke was still on....so now i dont know whats wrong, but im thinking its a problem with the carburetor. Anybody have any similar problems or ideas?
Old Nov 8, 2007 | 07:37 PM
ptowntsi's Avatar
Default RE: New problems on the F3
clean the carbs. i seriously think that is what causes 90% of peoples problems.
Old Nov 9, 2007 | 11:59 AM
kjohnson's Avatar
Seafoam!!
Old Nov 9, 2007 | 03:33 PM
Beksooh82's Avatar
idle jet is clogged? im a newbie to working with bikes, how do you recommend cleaning it? and the hell is seafoam???
Thanks for the replies so far!
Old Nov 10, 2007 | 01:28 AM
Beksooh82's Avatar
thanks for the advice.....uh unfortunately i read the writeup that was on this forum, and it seemed easy enough. So i went ahead but ran into a few setbacks. one.....where the hell is the waterpump valve that im supposed to disconnect? and two.......i guess the previous owner stripped the choke screw so i cant seem to remove it. if i drill it out how should i go about it:? any advice? once the carbs are off it seems pretty simple, i didnt realize i was going to run into so many snags along the way, thanks for ur replies once again.
Old Nov 10, 2007 | 08:12 AM
kjohnson's Avatar
Seafoam is a gas additive that works like "gas teatment" is supposed to.It is killer.6 bucks at Advance Auto.If a bike has been sitting and "doesn't quite run right",Seafoam is a quick and cheap try.
Old Nov 12, 2007 | 02:23 AM
Beksooh82's Avatar
thanks for the replies f3racer and kjohnson. The screws are phillip heads and its rounded top. The threads not stripped its the head thats stripped. I tried gripping them with needle nose pliers and it didnt work. dont have a dremel available to cut slots on them either. I bought an extractor bit but it doesn't work too well and if anything makes the problem just worse. I feel rather uncomfortable drilling the screws out, so i might just go buy a dremel tomorrow. Ill keep you guys posted.
