Need new fork...help please
Old Apr 8, 2010 | 06:09 AM
CBRstuart's Avatar
Default Need new fork...help please
Hey guys
Need a new right hand fork for my CBR 600F 1995
Do any other forks fit directly on without changing breaks or anything apart from the F3 ones? Just theres a few on ebay i need this asap, what year would fit directly on?
Thanks
Old Apr 8, 2010 | 08:40 PM
bobmilkman's Avatar
Only other F3 forks fit right -
F2 forks would also fit, but they are a step backwards in technology. F4 moved from 41mm to 45mm (I believe), so the would not fit.
People have done complete front end swaps to newer 600rr, which also have 41mm forks, but you need to swap everything down to the head tube.
Old Apr 9, 2010 | 05:06 AM
CBRstuart's Avatar
Thanks for the reply, however that was not what i wanted to hear
Finding it real hard to source a pair or even 1 F3 fork... I want my bike back :/
Old Apr 9, 2010 | 07:09 AM
bobmilkman's Avatar
Yeah it sucks - one of my forks is a bit bent at the lower triple clamp and I'm casually looking for a replacement on the cheap, but they are seem to be expensive. Maybe someone on the forums can help you...
Old Apr 10, 2010 | 05:49 AM
BPWilson_F3's Avatar
Originally Posted by CBRstuart
Hey guys
Thanks
A friend of mine has a wrecked 95 F3, I'll ask her tomorrow (well actually today) if the forks are still good and what she would want for one/both.
Old Apr 10, 2010 | 06:27 AM
CBRstuart's Avatar
that would be great, thanks!
Old Apr 11, 2010 | 09:42 AM
bandaid's Avatar
sorry to butt in on your post here but I am thinking about doing a swap to 03 rr forks on my f3. Does anyone know if I can use my front tire/rim off a 98 f3, or will the axle/disk brake not line up properly. I can get the whole assembly with trees and brake calipers.. just no rim or tire. I would just slide my wheel off and go try, but its a 2 hour drive for the parts, again any help is appreciated
Old Apr 13, 2010 | 02:08 PM
CBRstuart's Avatar
http://cgi.ebay.co.uk/Honda-CBR-600-...item3cac13825f
am i right in saying these won't fit?
Thanks
Old Apr 13, 2010 | 04:49 PM
bobmilkman's Avatar
Bandaid - you might need to build axle spacers to get the spacing right. Also, the rotors from an F3 (296mm) are a different size than the 600rr (310mm). You might run into caliper-wheel clearance issues. Better to just find a 600rr front wheel.
CBRstuart - They wont fit into your triple tee F4 have 43mm forks, F3 have 41mm. But you could swap the whole front end (I see that auction comes with upper and lower tees). It looks like the caliper brackets are different from F3-f4 (see pic of f3 forks here).
Check this thread out
Old Apr 14, 2010 | 03:51 PM
CBRstuart's Avatar
Thanks for the help guys
Does anyone know the rought dimentions of the forks and weight? Just i'm trying to get a courier price. I guess 1m long 10-20cm wide 10-20cm tall, abour 5kg in wieght?
Kinda random question i know
