need longer battery cables
So I've done a subframe swap to an f4i, and now the battery cables are too short. I need them to be like 6 inches longer. Question I have is does anyone know where I can get the special ends for them? The ends for the battery have special tabs on them, and crimp on to the cable. The other ends I need go to the solenoid switch and those are special ends as well. I don't have pics but I will put some up soon. I know you can buy cables and put regular eyelet crimp on ends which ill probly use for the battery terminals. But the ones on the solenoid Idk about. Best way to describe them is its a very small, long piece of metal that has the end bent up and over and crimped down over the cable. The other end of piece of metal has a small hole which bolts onto the solenoid switch. So I'm thinking of fabricating an aluminum piece and hammering the end down over the cable, and filling it with solder. Any suggestions or better ideas??
