Need help identifying hoses that attach to carb
Old Sep 22, 2018 | 08:08 PM
EagerNewbie's Avatar
Default Need help identifying hoses that attach to carb
Hey everyone!
It seems the horrible mechanic that I took my bike to before stole a bunch of various things from it. Ive been learning to do my own maintenance, and upon removing the air box, I realized that I was missing 2 hoses attached to the carbs. I've read somewhere that they are drain lines, but whatever they're supposed to connect to is missing, too. It would be a great help if you guys could point me in the right direction, as the parts diagrams I've been looking at are more confusing than anything else. Specifically I need to know what they're called, as well as what they attach to. Pictures would be greatly appreciated.
Old Sep 23, 2018 | 09:34 AM
Hey there. The hoses that your wondering about, where on the carbs do they connect?
Old Sep 23, 2018 | 09:59 AM
Upon further inspection, they are not the drain tubes. The missing hoses are supposed to be on either side of the main tube in the center of the 4 carbs. Between carbs 1 and 2, as well as between 3 and 4, is a node that swivels up and down. When I funneled fuel into the bike and started it to identify leaks, it was from these 2 nodes that the gas was pulsating and leaking from. I think maybe they are air vent hoses that potentially attach to the air solenoid valve? I'm not sure what the valve attaches or what parts I need to complete the system.
Old Sep 23, 2018 | 10:43 AM
If the node you're referencing is brown and plastic, those are fuel lines. If the node is metal and Y shaped, those are for coolant.
I happen to have my bike apart riggt now and will take pics of the air hose routing later today.
Old Sep 23, 2018 | 10:59 AM
This picture of carbs has what I am missing. You can see between 1 and two, and between 3 and 4 there are hoses attached, and they come together at some assembly point. These are the pieces that I need, and an understanding of where the entire assembly connects to when put back on. Thank you so much for taking the time to respond.
https://www.ebay.com/itm/1987-Honda-CBR-600-F-CBR600-CBR600F-Hurricane-Carburetors-Carbs-Cab-Assemblies/263756428109?_trkparms=aid%3D222007%26algo%3DSIM.M BE%26ao%3D2%26asc%3D20180306143914%26meid%3D093c16 40807c49798732e9b837190d04%26pid%3D100935%26rk%3D3 %26rkt%3D6%26sd%3D253363033849%26itm%3D26375642810 9&_trksid=p2056116.c100935.m2460
Old Sep 23, 2018 | 11:12 AM
This picture shows the missing pieces. Attached between carbs 1 and 2, and between 3 and 4. The piece they meet at I am also missing.
Old Sep 23, 2018 | 02:22 PM
Question. What year is your bike? You posted in the F3 section. Those carbs are from an earlier generation.
Old Sep 23, 2018 | 02:27 PM
It's a 97
Old Sep 23, 2018 | 02:31 PM
This my my carb. I didn't have access to it earlier so I found an image on ebay that has what I am missing.
Old Sep 23, 2018 | 04:15 PM
Here you go. You can see from my pics, the white T fittings between 1&2 and 3&4 are connected to your air lines. The brown ones on the bottom are for fuel. The metal Y ones on the very bottom are for coolant routing. I didn't take a pic of those.
I've disconnected some of the hoses so you get a better view. But you should be able to see how they connect now.
