need help identifing hose by left side of tail
Old Nov 22, 2006 | 01:36 AM
sn0rky's Avatar
Default need help identifing hose by left side of tail
theres a hose that doesnt plug into anything or fell off, its on the left side of the tail by the helmet lock?
anybody know what it is?
as it was leaking earlier
Old Nov 22, 2006 | 01:53 AM
cbr_newbie's Avatar
Default RE: need help identifing hose by left side of tail
by your helmet lock?
Old Nov 22, 2006 | 02:08 AM
sn0rky's Avatar
yes.. opposite side of the exhaust
Old Nov 22, 2006 | 03:48 AM
gerharddvs's Avatar
The closest pipe to that aria I can think of is the breather pipe for the fuel pump (which is very thin like a vacume pipe) but it doesn’t come back that far and it shouldn’t be leaking any liquid.
The best is to post a pic so we can see.
I suspect that somebody was probably rooting back one of your over flow or breather pipes.
The tank has a overflow pipe that comes to the lid and if you poor water over the closed lid it will come out at that pipe. The same will happen if you overfill the tank.
Check what size and shape the pipe is. That could give a hint.
Old Nov 22, 2006 | 04:07 AM
sn0rky's Avatar
ORIGINAL: gerharddvs
that actually may be it, because i did fill the tank today and i might have over filled it, because it is the first time that it has leaked...
Old Nov 22, 2006 | 04:18 AM
sn0rky's Avatar
here ya go
right now its tucked behind the subframe
gerharddvs's Avatar
Like I said it’s very easy to test. Just poor some water over the lid of the tank while it’s closed. What happens is that the water leaks thru the little gap around the cap and runs out the overflow pipe. Don’t worry it won’t leak into your fuel cause there’s a seal there.
If this is the overflow pipe it should be routed to the bottom of the bike and not to the tail.
Old Nov 22, 2006 | 04:20 AM
sn0rky's Avatar
ohh!!!
so its the section before the tank..
must be it.. thank you very much!!!!!!!
Old Nov 22, 2006 | 04:25 AM
gerharddvs's Avatar
If that is the overflow pipe, personally I'd move it cause you don't want to get fuel on your rear tyre while driving
Oh, and I forgot to mention that if you open the lid you can see the little whole connected to the pype.You could just squart water down there.
Old Nov 22, 2006 | 04:41 AM
sn0rky's Avatar
whats a good place to move it too?
