need help!!
Old 03-13-2012, 12:26 PM
f3kid's Avatar
Default need help!!
hey everyone need some help here just started riding this year and bought a 95 cbr600 f3 with about 11k...i put about 60 miles on the bike myself but now im having some tropuble and dont kno whats goin on maybe some one can shine some light...on my ride home from work it stalled out on me i pulled over checked everything over and everything seemed fine so got it started and about 1/2 mile later stalled out again i had no throttle response either time..got it to pop start and parked it..now it will idle for a short period and then stall out and itll stall as soon as i give it throttle...fuel pump seems to be working pet **** is letting gas out of the tank..does this sound like a problem with the carbs?...i laid the bike down a few days before but ran fine same day and my ride to work the morning it started acting up...sorry this is so long lol
Old 03-13-2012, 06:12 PM
MadHattr059's Avatar
First the diagnosis, odds are it's not carburation. Carburation doesn't "come and go".
The regulator/rectifier (r/r), on Hondas, is a traditional achille's heel. The symptoms
you're describing match the profile. That's my first point of interest.
The r/r is under the right-side cover. It's a square, black box w/ 2 big ears it bolts down
through. The face of it should be smooth, flat and blemish-free epoxy fill.
The connector that goes to it has 5 wires (3 yellow, a green and a red w/white stripe).
Check the connector and r/r, for warped, melted plastic/burnt pins/melted insulation
(basically any sign of heat damage). If you see anything along those lines,
the r/r is probably at fault.
Check that out and post back here. Then, we'll take it from there.
Welcome to the forums and hope this helps, Ern
Old 03-13-2012, 06:31 PM
74demon's Avatar
did you run out of gas maybe? try putting it on reserve and see what happens.
...and, welcome to the forum.
Old 03-13-2012, 06:41 PM
estate4life's Avatar
February 2012 ROTM
In additon to Ern & Demon....what color is your fuel filter? If it's the 95'.....fuel filter clog may also show this type of symptom....
Petcock reserve is north, on is south....
You said bike was laid down? Ran fine then this happen....gotta check any loose vaccum hoses, bent, that's may occur...
When bike shuts off throttling....something is short, not balance (air, gas, sparks)
Old 03-14-2012, 07:12 PM
f3kid's Avatar
Negative on the r/r being the problem no signs of heat damage anywhere on it...and no I did not run out of gas if its in reserve or on position makes no difference.... And if something is clogged could it go 20 miles or more cuz that's how far it went after I laid it down
Old 03-16-2012, 12:29 PM
Sounds like my problem, kinda. Mine died, dead lol. Sounds like everyone goes through this...... makes me feel a little better
Old 03-16-2012, 01:06 PM
74demon's Avatar
Check you battery voltage. Standing and charging. Lets see if its charging and make sure the battery cables are clean and tight.
Old 03-17-2012, 11:23 AM
f3kid's Avatar
Ok so there was no sign of heat damage on my r/r and I checked the wiring and other connectors and no sign of damage anywhere but I got a used r/r from a buddy and put it on with a new battery and a fresh full tank of gas and she runs now and I took her for a ride and fingers crossed ill see in another few miles if anything happens hopefully its all good thanks for the help everyone
Old 03-17-2012, 11:24 AM
f3kid's Avatar
And with the bike running the battery is at 14.5V so I kno the charging is working well
Old 03-17-2012, 04:40 PM
f3kid's Avatar
ok nevermind didnt even last today..it stalled when i was letting it warm up today when i was planning on riding it while idling itd stall as soon as i touch the throttle...wat is goiiinnnggg onnn??????
