My first CBR 600 F3
Old 05-13-2009, 05:49 PM
I use a VistaCruise on our bikes. It's cheap and effective. I used this same model on bikes I had in the early 1980's. The only thing I had to do was grind down the thumb lever so that it was shorter. With the handle bars at full right lock, the little lever would hit the tank. I was afraid I would dent it or scratch it over time. It works really well for long distance riding and allows you to take your right hand off the throttle for a few minutes to relax it. You may even find it in a local shop.
Old 05-13-2009, 09:41 PM
MikeSVX's Avatar
Normally right at 40mpg, but I did get about 46mpg (and a sore butt) driving 55mph on the highway straight through a tank.
Old 05-13-2009, 11:07 PM
marc0011's Avatar
They also gave a recommendation along jpanside@gmail.com's which was not highly recommended.
Originally Posted by gangofhoes
Mythbusters tested the effiency of drafting a semi. If you can stay 8 feet behind you can get up to 14% better fuel economy.
Old 05-23-2009, 12:24 AM
FlexCBRF3's Avatar
Originally Posted by idodirt
On the inside of the windshield on the left and right are small covers held in place by 1 screw. The lower ends are just slipped into slots and have some foam padding around them. You might be hearing a buzzing or vibration coming from them. Try adding a little more foam packing behind them to quiet them down. I've seen the fuse cover make a similar noise, but not as loud or as often. None of these things are critical, just little anoying.
ugh thank you so much! I had tightened the screw but still it's an annoying little vibrating/ buzzing noise... I will have to do this tomorrow
thanks again!
