My F3 just started running ****ty....Then Died...Now won't start
![Thumbs down](https://cbrforum.com/forum/images/icons/icon13.gif)
My 95 F3 started running real rough then died.....It felt like it was running on 2 cylinders....Or the timing was off.....Sounded like a v-twin.....I check for spark on 3 out of 4 plugs, all were good or atleast had spark....The fuel is getting there I can see it sprayin out the jets....I think its a short or something electrical....???
Has anyone had similar probs??....Or have any idea whats going on with my CBR???
I it happened all of a sudden while you were riding, I'll bet you blew out a gasket or seal, or had something get in the way of airflow into the carbs. I'd take them out, and throw compresse air through the lines, and clean the carbs while you're in there. You'll be able to do a more thorough inspection of everythign whiel you have all that out, anyway.
on
1 Post
The reg overheats & causes problems, you need to run a voltage check on it while the bike is hot to get a good reading. The Reg's are the CBR's Achilles heal.
Whoops, sure read the post before going off, recharge your battery, if the bike starts up & runs fine, then fer sure its the reg.
