my f3.5 rr
3 Attachment(s)
here is my f3.5rr
Attachment 39927[/IMG] 05 rr tail Attachment 39928 custom H.I.D projector halo (yes that is the stock headlamp) Attachment 39929 f4i gauge swap this is what i have been working on, during the winter months. still have more to do |
that looks good.. how is the projector at night?
It's not as wide as before. I get 1 lane instead of 2 lane wide
Looks cool. Liking the polished rims :)
Bike looks good! Did you polish the wheels yourself? Can you give us more on the projector when you get a chance?Tail looks so good on there!!!!
Yea that was my first time polishing rims. It wasn't hard at all. paint remover and some sandpaper. Most of the work I've done to my bike,I found how to's here on the forum. Just use the search. The headlamp i used a old fog light from a car. Cut the guts out ,put the hid in there. For the lens. I sanded all the bumps off the inside of the stock lens. Ill post some pics when I get a chance
When you get the chance, could you take a straight on picture of the tail? and maybe a couple from the side? I'd like to see how you did yours since it looks so clean. thanks!
i couldn't find a custom headlamp replacement for my f3 so i had to D.I.Y.. i use some heat to split the lends from the housing.. and then started sanding the inside of the lens with a heavy grit sand paper (think i started with 60 grit).
[IMG]http://i306.photobucket.com/albums/n...223_081925.jpg |
1 Attachment(s)
from there i kept moving to a finer grit sandpaper (100,220,4 something,600).after 220 ,started the wet sanding and thats when it started to clear up. i did it all by hand. i stayed away from any power sanders cause i didn't want any uneven sanding.
Attachment 39801 after i got the bumps out and started to look clear . i went out and got a headlamp restore kit. |
now with a clear lens, i put in my projector light in. people were asking why i didnt just put plexiglass . i was worry about the heat from the headlight and getting the bend to macth
